Can I now go and by a modem/router?
My exchange was enabled on 18.02.04 and have been informed that activation will be on 26.02.04. Does this mean that I can now get a modem,etc, or do I need to wait for any other confirmation?
Many thanks
There is no guarantee that your line will be suitable for Broadband right up to the time that it is activated and it could fail at any stage until then.
If you dash out and buy your router then you are in effect taking a gamble.
The risk is up to you if you feel confident about your success.
I suggest you check out what is available, select what you want and look around for the cheapest supplier. Most mail order can supply next day, just check they have loads of your model in stock.
