Can I login early?
mrfdes
Can I login early?
The provisional date of my broadband to be activated is the 13th (Saturday)
However, as my old service provider will be cut off tomorrow, I try the router out occaisonally to see if the ADSL light is on steadily (indicating an ADSL connection is present). Tonight it was Smiley However, my status page still says activating line.
So would I be able to log on and use my connection now?
Please note: I have never had broadband before, so its not left over from a previous connection, I'm currently using netvigator (who are awful!).
A quick answer would be preferable.
Thanks In Advance
Frankie Deschacht
Can I login early?
If the line is active and you have your username password then you should be able tp login ok. The paper work will take time BT will have to fill in the paper and then tell Plusnet who put it on the portal. So there could be a day when its active but hasnt been proccessed.
Login you have nothing to loose
mrfdes
Can I login early?
Well i tried...
It syncs, and all, but no connection Sad
And my router control panel said status is activating, so I'll have to wait...
Can I login early?
Try calling plus net. My line went active last Wed instead of Saturday and as long as i was happy to start the billing period 3 days early the helpful person at plusnet turned my account to active.
It's worth a shot.
A
mrfdes
Can I login early?
i'll try that Smiley
On the phone now (on hold) They are open at midnight right?
mrfdes
Can I login early?
I HAVE IT! I HAVE BROADBAND! HAHAHAHA!
YEES YES YES!
Can I login early?
I think there's a rule about all caps posts :razz:
Glad to see you've got it!
Can I login early?
YEES YES YES!
hahahaahah
