CONSTANT DISCONNECTIONS SORT IT OUT
Im having constant disconnections on my broadband service which basically means theres no point having it.
Does anyone have any idea what there doing about it ? or should i just go and find another Bband supplier ?
1 REPLY
Do you know if your on IPStream, BTMax or Tiscali-LLU? If your LLU then there are known problems.
http://portal.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=adsldial
