CLI Settings......
CLI Settings......
I need to add a phone number in the CLI Settings but I cannot find it in the Connection Settings part of my Member Centre. Can anybody help as to where it is?
I am currently logged in as myself through my son's account and need to enter his telephone number so he can configure my ADSL on my system from his house - he is on Plusnet as well so he can do this.
CLI Settings......
CLI only applies to people using dial-up, not ADSL. Smiley
Thomas
CLI Settings......
Can my son access my account through normal login via his connection.....ie boot computer and log-in from start and not log-in after he has established his connection?
CLI Settings......
No, unless he already had ADSL enabled with Plusnet on the same realm e.g. username@plusdsl.net or username@plus.net
Chris
CLI Settings......
So I understand that you both have PlusNet ADSL enabled on your telephone lines and you are not trying to to dial into PlusNet at all. If so, I believe you can just log in from scratch using whichever ADSL login details you wish to use.
