Buying an ADSL modem/router
Technically speaking, should i see improved pings over a PCI internal modem?
I'm not sure to be honest, if you did, it probably wouldn't make a massive difference.
What are your ping times?
You can often see improvements changing from a USB modem to router but you probably won't see much of a difference from a PCI card unless it was really bad.
I used to use the green usb thingie stingray thing that ive had for years, then i swapped over recently to a PCI card and saw a ping drop to a nice constant 22 in spec and in gameplay a nice static 27, now compared to the USB thing pings would be spec 29 and gameplay 35+
Due to some trouble with losing sync every so often i decided to go and buy the NetGear 834 v2 and its pinging around the same as the pci card. Ive only had this a day or 2 and no complaints at all with it, at this stage i would highly recommed one of these,
NetGear NG834 Version 2 Modem/Firewall/Router
Price £71 inc VAT and Delivery
