Browsing stops but email & ping OK..!!
This bizarre - I have hunted high and low for a solution, can anyone throw some light on this.
New BB connection. Conect no problem, everything works absolutely fine. For about 9 minutes.... then all browsers I have tried stop working. It's almost like someone has switched off the DNS server.?? Always about 9 minutes into a connection. If I reboot the machine, it works fine again, for about 9 minutes, then "connection timed out" (FireFox) IE is the same, BUT email carries on working fine and I can ping any server I like and it sends and receives packets no problem at all.!! but to be able to use the browser again I have to reboot the machine... here is what I have tried....
USB Modem Upgrade drivers
AdAware Scan
AVG AntiVirus (Scanned - then tried enabled disabled)
Norton Anti virus (Scanned - then tried enabled disabled)
Windsock Fix
USB hub (own power)
Internet Explorer
FireFox
Arrgghhhhh !!
Why is it only the browsing part that fails after 9 minutes - why can I still connect to mail servers and ping other servers
Arrgghhhhhh !! :shock: Cry
1 REPLY
are you using a router?
