Browser freezes - still
The problem persists.
About every five minutes on average during general web surfing the browser freezes. I click on a link and nothing happens until 30-60 seconds later.
Winipcfg reports that the new DNS addresses are being used already. I've tried setting new (and old) DNS addresses explicitly in dial-up connection properties, or server-assigned values, but it makes no difference which I use.
It's not a fault with the phone line, because I've experienced that and the symptoms are completely different, i.e. no ADSL connection at all.
I can be listening to a 128kbps HTTP audio stream when a freeze occurs and there is no interruption whatsoever to the music, so it's not the "Internet being slow."
What's interesting is that if I try to run Winipcfg during a browser freeze, that freezes too, before the IP Configuration info finally appears. Running Ping from the DOS prompt is exactly the same.
Help!!!
1 REPLY
RE: Browser freezes - still
i get the very same thing m8
every thing else works eg emails,downloads via file share,,every thing except web work
i call this the HTTP Freeze
something to do with DNS i think
