Broadband
silvercliff
Broadband
Hi
I am using one of the first modems Binatone ADSL 500
if I was to use a newer one would it improve my connection/speed etc.
obliged Job Harris
1 REPLY
Fixes: 57
Broadband
The odds are that it won't support the up to 8Mb speeds.
Normal recommendation is a router connecting through a network connector not a usb port.
Suggest contacting the manufacturer
