Broadband set up with BT Voyager 240
I have a Mac running Tiger, is it straight forward to set the Bt Voyager 240 4 port router up with this computer and do i need a separate modem?
1 REPLY
Denzil
You don't need a separate modem - there is one built in to the router. Don't know much about MacOS, but it should be easy enough. The router will have web interface where you type in all the settings, so you open your web browser, type something like 192.168.0.2 (the router manual will tell you the number) in the address bar and it will take you through a setup process.
MacOS might pick up the router automatically, if not there should be an internet connection wizard somewhere where you tell it what kind of connection you have.
