Broadband premier users..
can you get to www.hsbc.co.uk? I've been trying for days from home and keep getting nowhere, yet at work on demon internet, goes straight on. weird.
Yep I can access it no problem here!
*EDIT* I can't ping it though.
Indeed it does work.
Midville
Yes its ok here too.
Yup,
Works fine here too.
Its working fine here.
What settings do you have for your DNS Servers?
The 4 servers available are:
212.159.6.9
212.159.6.10
212.159.13.49
212.159.13.50
If you can with your connection software, set them manually and see how that works.
Stuart copy and paste this into your browser and see if it works :- 161.113.0.1
If it does then darkskye is spot on.
i've got
212.159.13.49
and
212.159.13.50
Still having problems accessing from home.
i'll try the other 2.
Cheers.
tried that, still having problems. The Heading of the page loads at the top of internet explorer, but the content on the pages is taking ages and ages and not loading. i'll go n get some breakfast n come back lol. Tongue
Hmmmm. What security progs are you running? Could you temp lower your firewall and/or privacy settings then try it again?
just windows firewall. its weird.
Can't Ping it!
Strange :?
its not strange that you cant ping it, it stops the simplest DDoS attack of pinging the site.
i'll give opera a try, its one of my favorite browsers actually just never got around to putting it on at home.
