Broadband phone set up
I have followed the set up keeps saying registration error 479 can anybody help before i go mad :twisted:
Plusnet Staff
Plusnet Staff
Are you using Xlite? If so, on the Topology tab try changing the IP address option to "Discover global address" and see if that helps. Mine's set up the same as the guide except for that one setting and works fine, but gives a 479 error if I set it to use local address, not sure why.
broadband phone
comes up with service unavialable all the time ?Huh
Plusnet Staff
Plusnet Staff
I just checked your login to make sure it isn't a problem our side and it works OK, could you post a screen shot of the settings page?
