Broadband Router - Difficulty connecting in daytime
In the daytime,when I switch on my PC and Binatone ADSL 2100 router, I have difficulty connecting to ADSL. All lamps switch on with the exception of PPP , which remains off. Switching the router mains switch off and on does not cure the problem. I have found though If I then use dial- up that the PPP lamp sometimes then switches on . I do not encounter the same problem after 6.00 pm though. Any ideas ?
