Broadband Plus and SMTP
I have just signed up for Broadband Plus and I noticed on the features list that SMTP is not included as a service, does this mean that I will not be able to send mail from applications like Outlook express?
LiamM
Yes, you will be able to send mail using SMTP through Outlook Express or any other similar mail client.
What you are reffering to means that you won't be able to run an SMTP server on your local machine and have your mail delivered to you in this way.
Cool.I was a bit worried I had shot myself in the foot with this move. I would have been ok as I use GMail via a browser but my Wife would have been affected. Phew..saved my butt.
Cheers for the swift reply...
