Broadband Max Upgrade problem.
I got an email from support on 2nd May saying that my broadband connection would be upgraded to ADSL Max. Can someone tell me if and when this will happen as I have just checked my account and it says I still have a 2mb connection. Is there anything I need to do at my end or is it down to you :?:
Chris
Plusnet Staff
Plusnet Staff
Fixes: 159
I'm having a look at your account now and it looks as though the upgrade has completed, the updated speeds had not yet filtered through to our system but I have given these a nudge for you.
Try rebooting your modem/router and you should see the new speeds possible on your account.
*Edit* Just looking here it appears your speed is currently at around 1 Mb, if your modem/router syncs higher for 3 days this will increase automatically.
 Chris Parr
 Plusnet Staff
I have just rebooted my router and its still reporting 2mb. I'll give it another try later and see if that makes any difference. Thanks for the very quick response.
Chris
Just to let you know I have just done a speed test and this is the result I get.
Linky
Moderators note by James (sallyandjames) : Changed [img] to a [url] as the image was stretching the page somewhat. Wink
