Broadband Fault Chacker
thekitesociety
A very silly question - to save my hair being pulled out.
The following was posted on my ticket (question) at 8:43 this morning.
Broadband Fault Checker - Connection checks [ In progress ]
The tests on your broadband connection have now started. Please check this Question in about two hours to see the results of the tests.
How long do these take? My assumption (probably wrong unfortunately) is that these are automatic - hence the check in two hours bit.
From the date stamps on my tickets, I'd say about 15 minutes.
I ran the test night, received the email
"The tests on your broadband connection have now started. Please check http://portal.plus.net/wizard/ in approximately 2 hours to see the results of the tests."
...but darned if I find the results. Not attached to the ticket, went into the bb checker again just in case, not there. Where are the results?
