Binatone usb modem poor connection
hi can anyone let me know an easy way to boost my speed ive done a speed check and the best ive got is about 295 any help will be much appreciated
thanks hilly
What product did you sign up for (i.e. what should your connection speed be)?
Also tell us what ADSL modem or ADSL equipment you have and what windows version you are using.
You may need to tweak your settings: see MTU Tweak
Also check your wireing is correct: ADSL: Wiring and Filters.
Also make sure you have done the checks detailed in ADSL: Trouble Shooting.
Cheers
Peter Cool
You can try tweaking the settings yourself using "DrTCP"
or install "DSL Modem SpeedUp 2" which one you have run it will tweak the settings for you, albeit to it's own preferences and maybe not the best.
Type either into a search engine and you'll find where to download them.
If you search the forum here, you will also find umpteen posts on "maximised speed" settings.
Also read through Connectivity Troubleshooting found on the right hand menus of the Customer support pages.
If you are running XP, make sure you have all the windows updates including Service pack 1 (SP1).
Also try with all your normal phones disconnected, and if possible pluging your ADSL modem directly into the master socket (via the filter is you don't have an adaptor from RJ11 (on the end of the modem cable) and the BT plug.
