Binatone 500
Binatone 500
Hi All
I ordered DSLconnect 250 for my sister - I'm pleased to say it was activated in 5 days and modem received on day 6! VERY good service from PlusNet there, I'd like to thank them. Very speedy..
However I shall be setting the modem / DSL up Saturday - Does anyone know if what come's on the current CDROM are the latest drivers, or would it be a good idea to download the new ZIP file that's available on the PN website.
It's a Windws98/SE machine BTW.
Many thanks
Glen
Binatone 500
Use the drivers that come with the modem. I think the drivers you refered to on PlusNets website are for the old 2 light version, and will not work with the 3 light version you will be getting.
Binatone 500
Best bet would be the CD-ROM, because they more than likely will work (have had horrible experiences of using web drivers that are incomplete :p)
If not search online for binatone drivers, although I don't think the binatone website will have them because it seems to be pretty poor in that respect. You could try some driver sites to see if there are updated versions though.
Binatone 500
Thanks all - I'll stick with what's on the CD. At least it'll be a supported config as far as PN are concerned if we run into problems.
Glen
