Binatone 500
Binatone 500
im having a few problems.
i left my broadband on for about 4 hours came back to it saying "connection 1 has disconnected reconnect? i clicked yes, then it said the modem wasnt installed. i check device manager to find its vanished.
and now i have no green light on where it says Line. the power light is on.
anyone know wots up?
1 REPLY
keithcalder
Binatone 500
Check your drivers are intact, sound to me as though they aren't installed properly. I would re-install your modem drivers and try again. Hope this helps Smiley
