Binatone 500 and WinXP
I have the Binatone 500 installed and it works fine most of the time. On occassion however, it refuses to download from certain websites including fileplanet. I decided to have a look at the modem properties, but when I go into 'phone and modem options' in control panel, there is no modem listed. Any thoughts anyone?
Cheers
Ewan
It is treated as a network adapter, not as an analog modem.
It depends on which version of the modem it is. The 2 light version is installed and operats the same as a 56k dialup modem, the 3 light version is installed and operates as a network device similar to a NIC.
I suspect you have the more recent 3 light version so you need to look in network connections in control panel.
