Binatone 2100 & Norton AV
Smiley Hi. I am new to broadband so I am not sure if my problem is normal but if I turn on my modem router and then start my computer Norton AV is the last thing in windows to start. But if I start my computer first Norton AV starts normally then turn on my modem all the lights are lite on the modem but IE and Outlook express want to connect useing my old dial up connection.
Thanks for any help. Dave
Hi Dave,
In IE go to tools - Internet options - connections and select "never dial a connection - apply - ok.
This will cause IE to connect via your lan.
Havent used OE for a long time but from memory in the mail account section - -connection tab - ensure that it is set to connect through your lan.
Thanks Mark .
That as solved my log on problem and I now start my computer first.
Still a bit courious why it stops Norton AV untill everything else is loaded (but Norton firewall seems tobe in place) if I do it the other way round. Thanks again for your help.
Dave
