Big ole what the hell on this one..
Come on what day is it today?
Slam Reppy with attacks all day?
Was fine yesterday with only a handful of hits, now im getting a bollock load of em.
Anyone got a clue on this one?
If that screen capture is showing the frequency that you are being hit then that is very low compared to many and not even worth worrying about.
When it reaches 100s/1000s per minute or hour then you need to worry and report it as it will be effecting your ADSL speeds. What you are seeing is just general 'internet noise' that everyone gets and nothing to worry about.
I'm getting the same log from my Sygate firewal but from a 80.xxx.xxx.xxx IP rangel. Constant port scans and intrusion preventions
holdtight
i get the same in my sygate logs sometimes more
sometimes less, nothing to worry about perfectly normal traffic
and sygate doing as its meant to, its job.
