Better up-speed than down! Help with settings?
Hi
I'm getting terrible speeds on tests after updating my router's firmware. Is there anything I can do to get it back up?
Currently, ADSLGuide is telling me that I've got better up-stream speeds than down! Results are as follows:
Direction Actual Speed True Speed (estimated)
Downstream 140 Kbps (17.5 KB/sec) 151 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 262 Kbps (inc. overheads)
BroadbandReports said the following:
Your download speed : 85927 bps, or 83 kbps.
A 10.4 KB/sec transfer rate.
Your upload speed is much faster than down.. have you tweaked?
Your upload speed : 242905 bps, or 237 kbps.
Why is this?
I'm using the SAR715, with the latest firmware. Can anyone help?
Thanks in advance.
