Best setup
Best setup
Whats the best setup for a single-user bb connection? I currently use the USB binatone modem that came with my starter package. I've heard of quicker, alternative methods of connecting, but i need a reconfirming what these are.
Cheers
Best setup
Firstly, an old addage, "If it ain't bust, don't fix it". If your USB modem works OK, then for a single user, other connection methods are just going to cost you more money with limited, if any, gain.
The option is a modem router and a single network connection. However, unless you leave the thing turned on, it will be no better in "time to connect" than your USB modem. The main advantage with a modem router, depending upon model, is the built in firewalls.
Best setup
Thanks for the advice, I 'm happy with the service so I think I'll leave it be! Smiley
