Best Settings For Plusnet 1MB Homeworker Pro ?
Can anyone please advise on the above. I tried using the network optimiser program and found that reduced the speed slightly. I get good speeds anyway, but would like to squeeze every last drop of performance out of the connection, if possible.
What values should I put into DrTCP?
I'm using a Conexant PCI modem.
Hi
I found that using MTU of 1478 and a Recieve window of 25884 gave me the best speeds fwith !Mb connection. Speed testing using Plusnets Bandwidth test, I constantly get 954 Kb/s.
Matt
Thanks very much.
