Belkin router F5D7630-4A - locks up & has to be rebooted
Hi All,
I recently upgraded my excellent Netgear 11mbps all-in-one router to a Belkin 54mbps ADSL modem with wireless router and am having trouble.
Every so often, for no apparent reason, the connectivity is lost both on the wireless network and Internet access. The web-based admin page is unavailable and all I can do is remove the power and restart it. This resolves the problem and I can continue until it locks up next time!
I've upgraded to the latest firmware and tried various configuration tweaks but it keeps happening.
Normal usage is great and it runs perfectly apart from these lock-ups.
Any ideas?
Thanks,
Jeff
1 REPLY
does the router that you have now, and your computer have an ethernet socket? if you wire it straight through and there is still a problem, then it shows its the router
Craig
