Belkin Router
Belkin Router
Just bought a belkin 7630-4A, is there anyway of fiding out your line stats on this router. it doesnt even seem to display simple things like your line upload/download speed and connection uptime. :shock:
Belkin Router
Hmm, just had a flick through the online manual and there doesn't seem to be any mention of line stats, etc. - which is odd because it seems like a very feature-packed router.
For line statistics, such as the attenuation and SNR figures, you can raise a link:contact us ticket and ask them to perform a "whoosh test". This will give you the figures you're after.
lowry
Belkin Router
For line statistics, such as the attenuation and SNR figures, you can raise a Contact Us ticket and ask them to perform a "whoosh test". This will give you the figures you're after.
I did this, and it is useful information to have. Remember though that you will lose synch briefly when the test is performed Smiley.
matt Wink
Belkin Router
Thanks for your replies guys, it is very strange that this router does not display any line statistics yes, not even your line speed or dsl connect time!
I have tried to ask plusnet support for a whoosh test on 2 seperate occaisons but both have been returned we will only do this test for you if you have a fault which is kind of a bummer. Guess im stuck to a no line stat router, which is s shame considering its spec and price tag. Cry
Re: Belkin Router
There is a hidden menu the part of which you require, line stats can be accessed after you are logged in.
Login to the router and then go to the following
(assuming http://192.168.2.1/ is the address of your router)
Line Stats (including dB and SNR readings)
http://192.168.2.1/ADSL_status_main.stm
WAN
http://192.168.2.1/atmint.stm/3
http://192.168.2.1/isp.stm
Wireless
http://192.168.2.1/wireless_e.stm
http://192.168.2.1/wireless_wep.stm
http://192.168.2.1/wireless_wpa.stm
http://192.168.2.1/wireless_1X.stm
NAT
http://192.168.2.1/nat_main.stm
Firewall
http://192.168.2.1/firewall_spi_h.stm
ADSL
http://192.168.2.1/adsl_para_main.stm
DDNS
http://192.168.2.1/ddns.stm
No idea why Belkin don't link to these in their own firmware!
Some of them are very useful...
Taken from alt.internet.wireless.uk
regards
Jim.
Belkin Router
thats fantastic! thanks alot for that info jim, I can now for the first time find out my line db loss
Stream Type
Interleaved Channel Data Rate
Fast Channel Data Rate
Up Stream
0 (Kbps.)
288 (Kbps.)
Down Stream
0 (Kbps.)
1152 (Kbps.)
Operation Data
Upstream
Downstream
Noise Margin
24 dB
25 dB
Output Power
12 dBm
19.5 dBm
Attenuation
31.5 dB
53 dB
Belkin Router
Lne should be fine for 1Mbs but it can't support 2Mbs due to 53dB attenuation (this needs to be below 45dB or 43dB for 2Mb)
csogilvie
Belkin Router
Wow, thanks for that list cullenfamily!
Belkin Router
Seconded! There's a load of useful stuff there... why Belkin can't include at least one link to it all somewhere I do not know!
Thomas
