Belkin Router Setup
Trapper_Dave
Belkin Router Setup
I'm really struggling with this, my two previous routers didn't have any issues at all.
Is the connection PPPoE or PPPoA. Also is the encapsulation LLX or the other one with a multiplexer?
I've tried looking for the settings on both the site and this forum, but it's hurting my head. Cry
Alecto
Belkin Router Setup
PPPoA and VC based.
Is that the Belkin router that is so easy because it sets itself up automatically?
Tongue
There'll be a guide to setting it up on Google.
Trapper_Dave
Belkin Router Setup
It worked with that configuration initially for about five to ten minutes and its since refused to reconnect. Hmmm....
I'm at work at the moment, but when I get home I'll try and do it again.
Trapper_Dave
Belkin Router Setup
That didn't work. It's a F5D7632UK4A. I've found a bit more information on here, to take back with me and try again.
If all else fails I guess I could spend the evening on the phone again trying to get through to customer care.
Alecto
Belkin Router Setup
Or there might be a solution on the belkin forum.
Trapper_Dave
Belkin Router Setup
I've only just realised that Belkin products have a lifetime warranty, so I've asked them to replaced the F5D7630-4A that I had previously and the F5D7632uk4A replacement will be returned tomorrow.
Seems like a good result all round.
