Belkin F5D7630 lockups
Twice in my first week of use, the F5D7630-4A router has locked up overnight. In the morning I found the LEDs flashing and the router completely inaccessible. A hardware reset was needed to restore normal operation.
Has anyone got any ideas about this problem?
TIA
Eric
Have you checked if you are running the latest firmware in the router? Even new modems may not have up to date firmware because you don't know how long that stock was at the suppliers.
What does the light that was flashing indicate? Does the manual explain what that light normally indicates and what t means when it is flashing?
Have you also had ADSL for the same length of time as the router?
Yes, I've upgraded to the latest firmware from Belkin.
It was the ADSL data light which was flashing. All the manual says about this is that flashing means "WAN activity". When it's on steadily it means that it's logged on with the ISP.
In fact I got the router some weeks before I got my ADSL connection. I had it connected up and working as a (rather overspecified!) network switch. There were no problems during this period.
I've noticed in the security log that I've been on the receiving end of a number of UDP flood attacks, but I don't know if these have triggered the lockups.
Eric
there might be some bug in the routers code that makes it lock up under certain situations such as a UDP flood.. maybe post on their site or ask the help and support as they may be unaware of such clitch
Buz
Yes, their site doesn't have a discussion forum, but I've emailed their support department (which doesn't work weekends of course).
Eric
Look at this on broadband reports
http://www.dslreports.com/forum/remark,10070950~mode=flat
Many thanks for that link.
Eric
