Belkin DSL Router
Belkin DSL Router
Does anyone know how to get a Wireless Belkin DSL router working with DSL?
Do you need a DSL modem or does it simply plug into the BT socket on the wall?
It has a WAN port and has firewall features
RE: Belkin DSL Router
An easy guide is: If the router has a cat5 WAN port then it will most likely need a separate ADSL modem / router. If it has an RJ-11 WAN port (sometimes labelled "ADSL") then it most probably has an ADSL modem built in. If you have the model number I can tell you for sure.
I have a Belkin DSL router and you do definatly need a dsl modem. You also need to set set the Gateway to be theIP address of the lan side of the modem
