Being throttled
Being throttled
I have posted this before and there seems to be no solution but here goes;;download speeds great surfing the net useless, worse than a 56k especially
on this site its like I'm being throttled please help
RE: Being throttled
1. What OS are u using?
2. Which browser are u using?
3. Do u have Kazaa or simliar p2p clients installed?
RE: Being throttled
1 Windows xp
2 MS IE 6
3 No kazaa or p2p
There is nothing wrong with download speeds just surfing
RE: Being throttled
<snip/>
> 1 Windows xp
> 2 MS IE 6
> 3 No kazaa or p2p
[Disclaimer - I am not an XP user]
If download speeds are good - are u downloading by ftp or http? Are the results from speed tests ok?
http://www.adslguide.org.uk/tools/speedtest.asp
If only retriveing web pages is slow it sounds like a problem with the 'connection' options. In IE, check tools->internet options->connections (?). Is there an old modem connection there?
Are any proxies set-up?
Have u tried a different browser to see if there is an improvement? Try www.opera.com
RE: Being throttled
> <snip/>
> > 1 Windows xp
> > 2 MS IE 6
> > 3 No kazaa or p2p
> Are any proxies set-up? No proxies
> Have u tried a different browser to see if there is an improvement? Try www.opera.com tried opera no improvement
Speed tests say good
Its a mystery
RE: Being throttled
<snip/>
> Its a mystery
If both Opera and IE6 are slow to load pages then there has to be some common component their sharing.
Was XP a fresh install or an upgrade?
Any firewall/virus software installed?
Try
http://www.tweakxp.com/tweakxp/display.asp?id=958
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&threadm=1a95101c23075%245796c240%2419ef2...
