Basic question concerning router
While BT is testing my line to determine my optimum Max speed, does it need the computer and the router on, or just the router?
TIA Simon
1 REPLY
Just the router is all you ordinarily need, as it maintains its own internet connection.
The only time you would need your computer on too, is if you were connecting via a USB modem, or PCI based one.
