Bandwidth
Bandwidth
This month according to the usage monitor I have downloaded 11.75gb :O im on home surf which is no longer available, which is also uncapped. Do I risk my account being terminated or capped if I use it this much? Dont usually use it this much but my hard drive blew so had to download everything twice, hope I dont get charged extra or something for downloading loads :?
Bandwidth
Home surf is uncapped (i.e. unlimited) and will remain so until you decide to switch to another product, so it does not mater what your usage is.
michaelscott
Bandwidth
Don't worry. I'm approaching 28Gb Cheesy Cheesy Cheesy Cheesy :shock:
Bandwidth
Don't worry :p
Plusnet Staff
Plusnet Staff
Bandwidth
As rbentley says there's no reason to worry. Home Surf accounts don't have any bandwidth limits (just the type of download i.e. Peer-2-Peer and binary newsgroups) so you can use as much bandwidth as you like.
For the older account types like ADSL Home and Home Surf the View My Broadband Usage feature is there more for informational purposes than anything else so you can see how much you are downloading/uploading.
Bandwidth
Although you would have reason to worry if your hard drive is not greater than 250Gb capacity with usage like that!
Bandwidth
Apologies thought that was Gb on Tuesday but is only Mb.
Bandwidth
268gb in a day? That'd be quite a trick considering it's not physically possible Wink
Bandwidth
Heh rbentley you really use a lot, what you do? download 50 movies a day? LOL
Bandwidth
I'd say nearly 1/3 of it is uploads..i'm a fan of bittorrent. For example, i downloaded AA last night, downloaded 728mb, uploaded 846mb.
Bandwidth
Bandwidth
This option did not work b4 on me. I only used 0.75gb
Bandwidth
if we upgrade to 1 of the new home packages (with pemier for 21.99/month), would i be able to use p2p?
Bandwidth
Yes, there are no usage restrictions on any of the new Broadband Home accounts - you can use binary newsgroups, p2p, etc. Obviously if you buy the Boradband Home account with a bandwidth limit, you can only transfer so much / month - but there's still no limit on p2p, etc.
Bandwidth
Just for clarification, can you confirm you are on a ADSL home surf or Biz Surf account? If not, you don't have P2P restrictions anyway so there would be no reason to move to a new product.
