Bandwidth speed test broken?
I got regraded today and tried the speed test here but it says my speed is 0kbps. I tried it several times but the result didn't change. I've tried other tests on other sites and all is fine. Is it broke?
themoron :@)
I wouldnt worry too much about the speed test here, its not good for me either.
Use this one, always gives accurate results.
Bear in mind the speed test is not compatible with many popup blockers. If you are using programs such as Norton Internet Security or Norton Personal Firewall, disable them whist running the speed test.
