Bandwidth Usage
Griffo
Bandwidth Usage
With reagrds to the 'view my usage' option in connection settings. I signed up for the preier package, and the bar shows a max of 1GB for this month. Does this mean I can only use that amount, even though I registerred for the premier package?
Alecto
Bandwidth Usage
No
The small print on that page says:
The figure displayed at the higher end of the scale is an indication of how much bandwidth you have used. If you use more bandwidth this figure will automatically increase.
When you've used over 1, it shows 2, and so on.
Griffo
Bandwidth Usage
Ahh right my mistake. My excuse is it's early Monday morning. Thanks for clearing that up. Cheesy
