Bandwidth Over Limit
Went over my bandwidth limit - How does this occur? How can it be avoided?
[Moderator's note (by Chris P.): Topic and post changed from capital letters - please refrain from doing this as it makes the post harder to read, and is also considered rude]
1 REPLY
the_norris
A short and non helpfull answer would be :
Don't use the internet
Sorry could not help it Smiley
Now the helpfull answer:
You will need to look at what you use on the internet? Do you use any P2P (file sharing) apps? Steaming audio/video? etc
Also this month the Windows XP SP2 is out. If you have you PC to auto download updates - I believe is a a big file -100Meg-ish?
And it you have more than on computer connected to the internet - things can start to add up.
How much did you go over by? and whats you limit?
Phil
