Bad Bad DNS
Bad Bad DNS
Hi
Im experiencing big DNS problems. I cant connect to any sites but plusnet, its been like this for over 2 hours now.
My connection is fine, MSN works :-) but thats about it.
One site gets a bit boring.
I've tried power cycles of all my equipment and its still the same Sad
up til this morning my connection had been superb for 4 weeks, you make better upgrades and it fails.
RE: Bad Bad DNS
> Hi
Someone posted the BT DNS server addresses recently which made this issue disappear. Too bad I no longer I have them.
RE: Bad Bad DNS
You'r not alone, I'm experiencing the exact same problem,
No service all day and now major problems! Whats going on
Its usually so good
RE: Bad Bad DNS
I did keep them - tried them and it's made no difference.
:confused:
RE: Bad Bad DNS
> :confused:
Found them, too - not working here, either.
RE: Bad Bad DNS
> Its usually so good
I don't think its DNS. I cannot even ping IP numbers that I know exist! It's still routing issues as per all day. No fix I don't think. The release looks like pure PR to me!
How they can be showing a "green light" for connectivity when people are still having major problems is just plain disgraceful.
Has anyone had a response to a support ticket with any more info?
Regards
Emeric Miszti
http://www.uksecurityonline.com
RE: Bad Bad DNS
it's not that bad - I can access Freeserve and MSN - so that's a choice of three sites - it's like going to the days before Channel Four an Five on TV!
RE: Bad Bad DNS
Hey, you are one of the lucky ones!!
I can't even get to the portal Sad
Regards
Emeric Miszti
