Backup Dialup details needed.
Hi all,
Can someone point me out where the details for configuring a Backup Dialup say if the ADSL goes down.
I've found lot's of dialup number but none specific to being a backup
Cheers
Glen
I assume you mean for 56k dialup... Click connection settings on the left then click connection details and the number to dial and other details can be found there.
You can use the mobile (or roving number) of 0870 7063000 or
you can also use the 0845 number listed in "My account" - "Connection settings" of the member centre on the left of the screen.
However, note that you cannot use a dial in to access your account while you are connected via DSL.
