BT woosh test
BT woosh test
Hello
Does anyone know how to perform a BT woosh test on a line or can only BT do this?
1 REPLY
BT woosh test
It depends.
Only your ISP can perform a Whoosh test, and then they can only do this is you are an existing customer with an ADSL enabled line through that provider.
Or in other words, you need to a Plusnet ADSL user if you wish for Plusnet to perform one.
