BT Voyager USB Modem with PlusNet anyone ????
Hi.
Just got my line activated (Dec-10) and I got a mate's BT Voyager USB Modem for Self-Install option.
1. I'm having trouble getting the "Link" light activated on the modem, and ...
2. I need help in getting the cabling / splitter thing in the right order ; my line comes in at the hall where I have the socket box and 1 'phone then an extension upstairs where I have my PC (+ Modem) and a 2nd phone & a fax.
Does anyone have expewrience of using a Voyager with PlusNet and can they advise me on the right way to order the splitters / cables, etc ?.
Cheers ! EMail me at : jb@currantbun.com or johnbalmer@johnbalmer.plus.com
1 REPLY
RE: BT Voyager USB Modem with PlusNet anyone ????
The telephone splitter filter is needed for every active telephone point (where you have a telephone plugged in);
You will need to have:
Downstairs
Filter between the phone and socket downstairs.
Upstairs
End of extension:
Filter1: socket1 USB Broadband modem
: socket2 telephone, fax
You cannot have to broadband/telephone running from the same port!!
hope that helps
Eamon
> Hi.
