BT Voyager ADSL USB Modem
Hello All, newbie here.
Quick question, I just had my comfirmation e-mail today which has made me all excited Cheesy so I'm ready for some broadband at home. Now, I've been given a BT Voyager ADSL modem by a friend so I plugged it in and installed what drivers I could find (I used the ones from the BT CD that came with the modem) and it has put some icons for BT broadband on my desktop. Now, do I just ignore these icons and try to put in my own settings to connect to plusnet and it should sort itself out or do I have to re-install some clean drivers ?
Like I said I'm very new to this thing and any advice would be greatly appreciated.
Many thanks
Downsy
The main difference in the settings is the username and password - you're using the same adsl kit at the exchange to connect, so hopefully it should all work fine
Thanks for that, the setup computer side seems to be working fine and I've managed to get on the net Smiley . I'm having a bit of problems with the telephone sockets, but I'll have a bit more of a play before I get too stressed
