BT Voyager 240 Router
grimreality
Anyone out there who knows the settings please tell me ASAP.
I am looking for what you have to do to completely reset the router back to factory settings, and also what is the default username/password.
grimreality
Thanks for the quick reply but cannot get the page to load.
The username and password are admin
try this page its loads ok
http://www.fasthosts.co.uk/knowledge-base/?article_id=678
grimreality
Thanks, could not remember my password for the router so I had to reset as it had stopped port forwarding. All working as fine as possible now with the only issue being that I am unable to maintain a constant connection of more than a couple of hours without being disco'd for some reason.
Mand
Do you lose sync when the disconnections occur? If so have you tried the router in the master telephone socket?
You'd be worth raising a fault here so that the faults guys can run some tests for you if you have tried the above.
