BT Voyager 205 problem
Cos2005
BT Voyager 205 working fine with PC surfing, playing live on 360 no problem.
Problem But I cannot get torrent files to upload or download.
Any suggestions?
Can I ask have you opened the ports for torrents?
I have always found that for the likes of P2P and torrents that the answer to non downloads are that i don't have the right ports open
If you haven't opened the ports then try this guide to help you, just select the program you are using and follow the guide!
Linky
Cos2005
thanx for the link, I will give it a try! Cool
PortyAL
Hi
Just to follow on from this thread - I have a Voyager 205 modem also. I have the ports forwarded for BItComet as per the above link, but the problem is that whenever I open BitComet all other traffiic stops, i.e. I can't browse web pages or check e-mails when BitComet is open although I can download torrents. Even after I close BitComet I sometimes still can't browse and have to reboot the PC.
I'm on BB+ at the minute (considering upgrading to 10Gb PAYG)
Can anyone shed any light as to where the problem lies?
AL
have a search on google for voyager 205 hacks/tweaks.
There is a good tutorial on how to make the router faster.
I used to have the 205, and it made a huge difference.
