BT SERVICE INFORMATION ?
joecool
Hi twice today, after connecting to the internet have I had the msg
SERVICE INFORMATION
Close Window
You have been connected to this page due to one of the following reasons. You must now shut down your browser and Internet applications before attempting to reconnect.
1. The BTWholesale access circuit to your Service Provider is currently down.
Your service should be resumed soon.
Or
2. You are testing your local connection to BT using
‘bt_test_user@startup_domain’
Or
3. You are testing your connection to your Service Provider using ‘bt_test_user@domain’ where domain is your Service Provider domain name.
Or
4. Your Service Provider is currently unable to accept your connection request please wait until service is restored or contact your Service Provider for further information.
Or
5. You have attempted to access an invalid Service Provider domain.
What is the reason for this ?
Anything I need to do ?
Thx
This was occurring earlier in the week for some users and was perhaps down to this
The following DNS servers are currently failing DNS lookups intermittently:
212.159.13.49
212.159.13.50
This may result in errors when accessing websites and other services.
The problem is being investigated by our engineers, and appears to be a recurrance of the same problem experienced yesterday, which was solved within a few minutes by a reboot. We will perform further investigation as to the cause of this problem during the afternoon.
We expect this to be resolved in the next few minutes, in the mean time however, customers should find that manually specifying the following DNS server addresses will work-around the problem:
212.159.6.9
212.159.6.10
This was posted on service status but I thought it had been fixed. Maybe not.
Manually assigning your dns to the ones immediately above may cure this.
Hope this helps.
joecool
Hi appreciate yor quick reply,
everything appears OK at moment
Not quite sure about how to manually change DNS server addresses
Would I really need to ?
If all is ok now it may have just been a glitch.
Manually assigning dns depends on what equipment you are using ie usb modem or router etc.
If all is ok now then let it ride. If it persists post back and some of the forum members will keep you right.
joecool
Cheers ! Have a good night Wink
I too have had this problem repeatedly over the past few days
tried setting the DNS settings manually and the router message then is DSL disconnected
LiamM
Usually, reconnecting works. If not instantly, disconnect, leave for an hour and then reconnect. Wipes out any stale connections at exchange level.
mooblie
Me too... now stopped (I think!)?...
I was getting the same page:
QUOTE
Or
Or
Or
Or
UNQUOTe
...frequently from a PC at home on the network (but NOT from a Mac on the same local network/router/connection) between around 21-25th Feb. Seems to have stopped now.
joecool
Cheers Guys
