BT IPstream Home 1000 dB/line length requirements?
Any ideas for the limits required for BT IPstream Home 1000 , simmilar to Data stream or are the requirements a bit wider as its IPstream?
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
1 REPLY
As yet this product is still experimental.
Wholesale ate likely to implement limits when they are satisfied with the performace the product gives at certain distances etc.
The limits are likely to be the same as the Office 1000 / 2000 products as it is basically the same product, only difference being the bandwidth and connections at the exchange.
Chris
