BT Broadband
Fixes: 5
BT Broadband
Hi all
I'm thinking I'll try and get my inlaws mingrated to PlusNet from BT in a couple of weeks time when I go down there. I'll need to time it so I'm there when it completes to change router settings etc... as they wont have a clue what to do. I'm only there for 4 days so need to get it all kicked off before I go down.
As I say they are with BT at the moment. Does anyone know the easiest way to get a MAC from BT? What info do they need? If I remember correctly they don't set a username do they?
Phil
