BT 1800HG
BT 1800HG
Hi all
My new Router keeps cutting out, then reboots, runs for a bit then cuts out again.
Any ideas why this is happeningHuh?
please help
Ian Ward :shock:
1 REPLY
p_w_d_stone
BT 1800HG
Can you describe the sequence of events when the router cuts out. Do the lights on the router go out? All of them or just some? Is it the connection to the router or the connection to the internet that cuts out?
Have you tried upgrading to the latest firmware, running a factory reset and starting setup again fom scratch.
Is there a good air flow around the router, it's not covered or obstructed in any way is it?
