BROADBAND - Manual Connection
Hi
How easy is it to set up a Manual BROADBAND Connection? Could someone explain the process involved?
Could you explain what you mean by a "manual" broadband connection?
If you mean "How do you configure the equipment without using the installation program?", then the answer depends on the exact equipment being used, and may not be possible with some equipment.
Many ADSL routers can be set up and configured without using an installation program -- the process typically uses one or both of HTTP (ie using any modern web browser) and telnet.
Users of non-Windows operating systems may well have to use these techniques. (Perhaps that's the reason for your question?)
Manual as in via DIAL UP NETWORKING, like i use 2 with my 56k Connection.
thx
