BB plus dial-up at the same time?
Is it possible to use a laptop with a data enabled mobile phone to dial up Plusnet while at the same time my home system is permenantly connected with an ADSL broadband connection? I'd like to be able to use this while away from home.
If so does the laptop just get a DHCP alocated IP address?
What account/hostname should it useHuh
Peter
You can dialup at the same time as your ADSL modem connected, however, either one, the other or both may suffer from loss of data whilst the two connections are established.
Your best bet is to resignup for a free PAYG account so that you may use the laptop like that.
Thanks, I'll do that.
Peter
