BB, BT Lines and VOIP
chris_coops
I remember when I setup my BB acount I needed a BT phone line. Is this still required once the connection is setup.
The reason I'm asking is that at home we rarely use the home telephone, making most calls from mobiles. As such the line rental is a waste of money.
With the possibility of VOIP does this make a home phone line obsolete, apart from using it for a BB connection?
[/code]
1 REPLY
Cloudmaster
You still have to rent a BT line for broadband, even if you don't use it to make phone calls. I believe there are going to be talks sometime in the future to change this situation in some way.
