Automatically log on
Is it possible to get ADSL to automatically log on when I start up? Some of my software requests this and it always tries to dial my normal modem instead.
I have a Zoom USB ADSL modem and I generally run Win 2000 Pro and occasionally XP Pro.
Any ideas?
RE: Automatically log on
> Any ideas?
Hi
I have the fujitsu modem and that uses the dial up box to connect ( although it dosen't dial up). If this is the case with you just check the automatically connect box, when your software calls for a connection.... it will happen automatically.
Hope this helps
Nigel G
> > Any ideas?
> Hi
> Hope this helps
> Nigel G
You could also put the dialup in the Start Menu...Startup folder like I have and then uncheck the "prompt for password" etc. options so it auto-connects to Plusnet on startup after modem has already made an ADSL connection to local exchange.
Thanks guys. I'll have a look.
